- Mar 9, 2011
Up for grabs is a BNIB ZT 0561. I accept PayPal, fees are included in the price but the shipping is extra. Any questions or more pics just ask. Thank you
LES GEORGE VECP FOLDER SOLD
Never used or carried, no lock stick, seems to have avoided the issues that some of the V1's have had
Steel: .150" (3.81mm) thick, CTS-XHP
Handle: Titanium Frame lock, .150 (3.81mm) thick
Back spacer: Grooved Black G-10
Ambidextrous thumb stud
Phosphorus Bronze washers
Drilled and tapped for tip up / tip down.
Hole configuration is the standard 3 whole pattern so if you want a different clip, you have a lot of options.
Lanyard hole
4.9 (124mm) long closed
Blade, 3.4" (86mm) long, CNC flat ground to .015 (.381mm) before sharpening
Hinderer Lock Bar stabilizer
ZERO TOLERANCE 0561 $175
The 0561 features a premium stonewashed Elmax blade with a plain edge and ambidextrous thumb stud. The handle has a 3D machined 6AL4V titanium frame-lock and a G-10 front handle scale. Never used or carried
Overall Length:8.75"
Blade Length:3.75"
Blade Thickness:0.16"
Blade Material:Elmax
Blade Style: Drop Point
Blade Grind:Hollow
Finish:Stonewash
Edge Type
lain
Handle Length:5.00"
Closed Length:5.125"
Handle Thickness:0.58"
Handle Material:G-10
Color:Brown
Frame/Liner:Titanium
Weight:5.98 oz.
ZERO TOLERANCE 0551 SOLD
This Limited Edition Zero Tolerance/Hinderer designed folder features a black G-10 and bead blast titanium handle. The blade is tumble finish with dual thumbstuds. "0551 Hinderer design Made in the USA" stamped on back of blade. Tip up carry. Strong lock up, nice detent and perfect blade seating. Includes original box and paperwork. Never used or carried
Blade Length 3.5"
Overall Length 8"
Classification Manufactured Knife
Weight 6.0 oz
Additional Specs
Liners Titanium
Closed 4.625
Lanyard hole
Blade Length:3.75"
Blade Grind:Hollow
Finish:Stonewash
Edge Type
Handle Length:5.00"
Color:Brown
Weight:5.98 oz.
Blade Length 3.5"
Overall Length 8"
Weight 6.0 oz
Additional Specs
Liners Titanium
Closed 4.625
