Hi
Zero Tolerance 0561 has too strong blade retention detente. its taring my fingers. toooo strong. Any way to fix that? It wont open with the thump studs, only the flipper and it takes too much strength the jumping is cutting into my flesh.
ZT may have missed the problem between their mill and laser cut versions of the frame lock. That quick of change had to impact quality controls.
They didn't miss anything it was done that way for a reason. Who exactly are these marketed to again may I ask??? Remember, if it can't stay closed in your pocket while jumping from planes, crawling through the mud or running at full Sprint then what's the point. A knife opening when you don't want it to really hurts.
The same things were said about the 0551 when it came out and I'll agree that its a strong detent but look at the knife, its a tank and everything is overbuilt.
Maybe everyone needs stronger fingers![]()
The 550 has the same blade stops but opens with the thumb studs. My 0560 detent is way too much even after 1000 openings. It sounds like this is not a problem with everyone's knives, but mine is this way even with the flipper! And no - I am not pressing on the frame lock while opening. Very disappointed and I know the person that sold it to me on eBay was because of this. Beware!!
These changes are carefully thought out, prototyped and tested, and then implemented. The is change did not impact the stiffness of the lockbar.
Here is a link to the information you need to send the knife back for warranty repair: http://www.kershawknives.com/warranty.php
