- Dec 19, 2002
ZT 0801, ELMAX Powdered Steel
Our Price: "Add to cart for SPECIAL"
http://www.knifeworks.com/zerotolerance0801elmaxpowderedsteel.aspx
ZT 0801 ELMAX steel + titanium + Zero Tolerance + Todd Rexford = one amazing knife
Zero Tolerance and custom knifemaker Todd Rexford join forces to produce the Zero Tolerance 0801. It starts with a blade of ELMAX powdered... steel. ELMAX enables ZT to produce a blade with a razor edge, excellent edge retention, strength, and toughness. A stonewashed blade finish hides hard-use scratches and makes maintenance easier.
The 0801 handle is lightweight and durable titanium with machined grooves for a secure gripand a great look. The titanium handle features a secure frame lock that, thanks to the titanium, is extremely strong. The blade deploys using the built-in flipper. Just pull back on the flipper and the razor-sharp ELMAX blade rotates out of the handle on ZTs glass-smooth KVT ball-bearing system. No springs required; just simple, one-handed opening. Easy. The 0801 pocketclip is designed for deep carry and is reversible for left- or right-handed carry. Decorative pivot hardware completes the 0801's handsome look.
Manual open, KVT ball-bearing system
Frame lock
Quad-mount (tip-up/tip-down; left/right hand), deep-carry pocketclip
Steel: ELMAX®, stonewashed finish
Handle: Titanium
Blade Length: 3.5 in. (8.9 cm)
Closed Length: 4.7 in. (11.9 cm)
Overall Length: 8.2 in. (20.8 cm)
Weight: 5.8 oz.
Made in the USA
Frame lock
Handle: Titanium
Weight: 5.8 oz.
Made in the USA
