Zero Tolerance 350 Black Washed
Gizmoman
Fighting Irish of Notre Dame
Platinum Member
Feedback: +453 / =0 / -0
New in box...
Handled and opened..
$$130.00 Shipped to your door
**NOTE** I do NOT do Proxy sales for folks that have USA addresses
but live outside of USA..If you want an item..You must get
your contact in USA pay me and when they get knife..The
deal is complete and your contact is responsible to get it
to you.................
Need to move
$$125.00
Out Of Town 7/15-7/18
Specifications
  • Blade Length: 3.25 in. (8.25 cm)
  • Closed Length: 4.625 in. (11.7 cm)
  • Overall Length: 7.75 in. (19.7 cm)
  • SpeedSafe® assisted opening
  • Liner lock
  • Quad-mount (tip-up/tip-down; left/right hand) pocketclip
  • Steel: S30V, Blackwashed Finish
  • Handle: Textured G-10, Black
  • Weight: 4.8 oz.
  • Made in the USA
keithchefboy@aol.com
Slightly smaller. Slightly lighter. Just as aggressive. The 0350 is 10% smaller and weighs almost three ounces less than our flagship 0300. Yet it packs a lot of features into a size that some users prefer, especially for every day carry.
Like its larger counterpart, the 0350BW features the patented SpeedSafe assisted opening system. Deploy the blade quickly and easily, even in gloves, using the ambidextrous thumbstud or flipper blade protrusion. The blade is built of tough S30V stainless steel blade designed to provide the perfect combination of durability, wear resistance, and corrosion resistance. The blackwashed finish provides a non-reflective surface and helps emphasize the lines of the blade.
The 0350BW is equipped with SpeedSafe assisted opening making it easy to deploy its big, beefy blade—just pull back on the flipper. Believe us, with a blade this massive, SpeedSafe supplies an assist you’ll appreciate.
This high-performance S30V blade is paired with textured black G-10 scales for a secure grip and excellent mechanical strength even under the roughest conditions. The scales are flat rather than 3D machined like those of the 0300. A locking liner secures the blade during use. The 0350BW also includes ZT’s Quad-mount system for complete versatility. Mount the pocke clip in any of four ways: tip-up, tip-down, on the left side, or the right. There’s a pre-drilled lanyard hole for users who prefer to attach a lanyard.
