Zero Tolerance Emerson 0620 Tanto
Feedback: +2 / =0 / -0
Here is the collaboration done between ZT and Emerson - this version features the black tanto blade,waved for immediate deployment. Truly a great bang for the buck and will withstand the demands of every day carry
Take a closer look here: http://btacblades.com/collections/frontpage/products/zero-tolerance-0620-emerson-tanto
$200, always FREE shipping
Zero Tolerance and Emerson Knives put their hard-use heads together to create the new 0620.
It features a blade of ELMAX® powdered steel in a modified tanto style. ELMAX® provides the extreme edge retention, high strength, and toughness a hard-use knife demands. High wear resistance in a steel usually means low corrosion resistance, but not with ELMAX. With this advanced steel, you get both properties—which makes it an excellent blade steel. DLC coating enhances performance even more and makes the blade non-reflective.
Of course, the 0620 features the patented Emerson "wave shaped feature" that enables the knife to be opened as it is removed from the pocket. By the time the knife has been fully withdrawn from the pocket, the blade is deployed and ready for use. A small wave-shaped tab on the top of the blade is built to catch on the pocket seam, opening the knife as it comes out of the pocket. This Emerson instant-open feature is a favorite among military, rescue, and law enforcement knife users.
The handle features a machined G-10 front scale with a stonewashed titanium back. Blade lock up is ensured with a sturdy frame lock. Hardened steel inserts in the lockbar make it extra durable.
"Wave shaped opening feature"
Thumb disk for manual opening
Reversible clip
Frame lock, hardened steel lockbar inserts
Steel: ELMAX®, DLC coating
Handle: G-10 front, stonewashed titanium back
Blade Length: 3.6 in. (9.1 cm)
Closed Length: 4.9 in. (12.4 cm)
Open Length: 8.5 in. (21.6 cm)
Weight: 6.4 oz. (181.4 g)
