Zero Tolerance Hinderer in Blackwash!
Feedback: +2 / =0 / -0
Take a closer look at this awesome rendition of the ZT Hinderer in blackwash: http://btacblades.com/products/zero-tolerance-hinderer-0560bw
Zero Tolerance Hinderer ZT0560BW Blackwash
Now the ZT-Hinderer 0560 comes in our great-looking BlackWash™ finish. Like a battle-tested tool or a favorite pair of well-worn jeans, the BlackWash™ 0560BW has that already-broken-in look.
The 0560BW retains its ELMAX® powdered steel for the extreme edge retention, high strength, and toughness a hard-use knife demands. High wear resistance in a steel usually means low corrosion resistance, but not with ELMAX. With this advanced steel, you get both properties—which makes it an excellent blade steel. The ELMAX blade rolls out of the handle on the KVT ball-bearing system. Just use the built-in flipper to open the knife quickly and easily.
The handle is basic black 3-D machined G-10 on the front, and lightweight, strong 3-D machined titanium on the back. The titanium frame lock, with steel lockbar insert and lockbar stabilizer, ensures a rock-solid lockup every time. And to top it all off, the 0560BW is equipped with ZT's deep-carry pocketclip and Quad-mount system for tip-up, tip-down, left- or right-handed carry.
Made in the USA
KVT ball-bearing opening system
Titanium frame lock, lock bar stabilizer
Quad-mount deep-carry clip (tip-up/down; left/right)
Steel: ELMAX®, Tungsten DLC BlackWash™ finish
Handle: 3-D Machined G-10 front, titanium back, BlackWash™ finish
Blade Length: 3.75 in. (9.5 cm)
Closed Length: 5 in. (12.7 cm)
Overall Length: 8.8 in. (22.4 cm)
Weight: 6.4 oz. (181.4 g)
