Zero Tolerance 0770CF Assisted 3.25" Elmax Blade, Carbon Fiber Handles $150
brand new in the box
The 0770CF opens quickly and easily thanks to SpeedSafe assisted opening and the built-in flipper. Includes deep-carry pocketclip. For a final touch of class, ZT adds a handsome oversized pivot. Made in the USA. Assisted opening; Inset liner lock; Reversible deep-carry clip (left/right); Steel: ELMAX, stonewashed finish; Handle: Carbon fiber; Blade Length: 3.25 in. (8.3 cm); Closed Length: 4.3 in. (10.9 in.); Overall Length: 7.5 in. (19.2 cm); Weight: 3 oz. (85 g).
Zero Tolerance 0770CF-M390 Limited Edition Knife, 3.25" PlainEdge M390 Blade, CF $225
Limited Edition with a very limited quantity with M390 blade steel
Blade Length: 3.25" ~ 3 1/4" ~ 83 mm
Blade Material: M390 Stainless Steel
Blade Style: Plain Edge
Blade Thickness:
Lock Style: Liner Lock
Closed Overall Length: 4.30" ~ 109 mm
Open Overall Length: 7.50" ~ 191 mm
Handle Material: Black Carbon Fiber
Pocket Clip:
Weight: 3.00 Ounces ~ 85 g
Special Features:
Limited Edition
Speedsafe® Assisted Opening
Flipper Lever
Lanyard Hole
Made in USA
Zero Tolerance Hinderer 0566BWCF Assisted Opening Carbon Fibe (BlackWash)LIMITED $200
Limited Edition
The Zero Tolerance 0566BWCF is a Hinderer designed assisted opening folder. This knife is more compact than the larger 560/561. The blade is BlackWash finished Elmax steel which offers excellent edge retention, strength, and toughness. The front scale is carbon fiber. The back is stainless steel with a frame lock and lockbar stabilizer. Quad-mounting system with deep carry pocket clip.
Overall Length: 7.70"
Blade Length: 3.25"
Blade Thickness: 0.12"
Blade Material: ELMAX
Blade Style: Drop Point
Blade Grind: Flat
Blade Finish: BlackWash
Edge Type: Plain
Handle Length: 4.45"
Handle Thickness: 0.44"
Handle Material: Carbon Fiber
Frame Material: Stainless Steel
Weight: 5.30 oz.
Pocket Clip: Right/Left Hand, Tip-Up/Down
Knife Type: Spring Assisted
Opener: Flipper
Lock Type: Frame Lock
Brand: Zero Tolerance
Model: 0566BWCF
Designer: Rick Hinderer
Country of Origin: USA
Blade Thickness:
Pocket Clip:
Special Features:
Limited Edition
Flipper Lever
Lanyard Hole
Made in USA
Limited Edition
Blade Length: 3.25"
Blade Grind: Flat
Edge Type: Plain
Weight: 5.30 oz.
Opener: Flipper
Model: 0566BWCF
