ya thanks to all who replied!
Off topic, but do the Zero Tolerance knives have plastic washers? I saw a post and I was curious.
most ZT knives that have a standard pivot actually have Phosphor bronze washers in the pivot. The knives with the KVT bearing system use Metal bearings in a plastic captive washer so that if you need to disassemble the knife they dont go spilling out onto the ground. It also limits the amount of bearings needed for each knife lowering costs.
+1 on the 0801 its my favorite ZTSame material on both sides 0801. Re profiled a bit it is a great knife. Russ
Theres no bronze washers in the KVT pivots in the 560 or 801 the bearings are directly between the blade tang and the liner/frame.That's exactly what I've seen on all ZT's as well, I believe that even the KVT bearings rest against phosphor bronze washers rather than the scales themselves...at least on the videos I've seen of knives being dissembled that use the KVT system. They're all very well made and overbuilt to say the least.
It is rumored that ZT will be doing serrated versions of Elmax blades (check BladeHQ) such as the 0561BLKST.
Why people are so against nylon bushing in a knife?
