- Aug 26, 2025
Hey everyone, finally had a question I was unsure enough about to register and ask. I got this ZT0350 used a little bit ago that had some issues. The pivot and grip handle screws were loose, the opening was stiff, the blade was off center, and the torsion spring was pretty rusty. I adjusted it a bit to the point where the opening was OK, and now I'm noticing my frame lock looks to be barely engaged (pictured). It doesn't feel any different than it did, so I'm not sure if this was a me-caused error or something else. In the course of googlin' up on it, I saw that various ZT 0350 models got faked a bit, and I'd also like to be sure this is real. Per the stuff I can find online the most easy tells all point to real (T8 pivot, T6 everything else, all the pocket clip holes are drilled/threaded, the back side of the pivot is hexagonal (though as pictured it looked kinda round, had to push it out to confirm that it was hexagonal), and the liners/internals looked dead on to some of the real examples in youtube disassembly vids).
My basic questions are, is this real, and if so, is the liner lock engagement enough, something that can be fixed DIY (if I put enough pressure on it with a tool the liner pushes over slightly more for what I'd consider a better engagement), or something I need to be messaging Kai CS about?
