- Jan 26, 2012
Can you get the Benchmade blue lube in Ace or Lowes (a hardware store) or do you have to order it online?
I would think you have to order it. Hopefully others can suggest stuff you can pick up locally.
try a good coat of paste wax on the washers, use just like you would on a car.its what I use on my kershaws, and zt's when they get sticky or sluggish.
It sounds like weak detent is the issue. Because it takes more pressure to flip with the stud as opposed to the flipper being so close to the pivot. It effectively mimics a strong detent so bend that lockbar in for a stronger detent and enjoy your new flawless action.I think you may have hit upon the problem. It's a bit difficult to do what you say because the flipper extension is right where the lock bar is when the knife is have open, but I DID adjust the pivot when I first got it (it didn't open for BEANS) so it's about as loose as it's going to get without the nut falling off. I can definitely feel resistance when moving the blade around in the 1/2 open position, so maybe a lock bar tweak is in order. I'll give it a shot. Just to add to this discussion, it's really only with the flipper that it has an issue opening. I find it easy to get a good purchase with the thumbstud and it opens like a rocket every time.
