Never unwrapped or handled, fresh in the box.
Made in the USA
KVT ball-bearing opening system
Frame lock, lockbar stabilizer with hardened steel lockbar insert
Tri-mount (tip-up/down, right; left/right hand), deep-carry clip
Steel: M390, DLC coated
Handle: Titanium, DLC coated
Blade Length: 3.5 in. (8.9 cm)
Closed Length: 4.7 in. (11.9 cm)
Overall Length: 8.2 in. (20.8 cm)
Weight: 5.6 oz. (158.6 g)
0392PURBLKWC Custom Hardware by Rick Hinderer:
Steel pivot screw
Titanium tube spacers
Titanium handle screws
Titanium clip
Titanium filler tab
The 0392PURBLKWC Factory Custom was built as a partnership between Rick Hinderer and Zero Tolerance. The titanium hardware, including a custom titanium filler tab, is custom made and anodized by Rick Hinderer. With ZT's customary robust precision, we manufacture the blade from premium Bohler M390, then DLC coat it.
The handles are sturdy titanium with black DLC coating. The 0392PURBLKWC has a titanium frame lock, lockbar stabilizer & hardened steel lockbar insert for secure lock up. A built-in flipper and the KVT ball-bearing opening system make the 0392PURBLKWC easy to open, so you can put to work on the task at hand quickly and easily.
Each 0392PURBLKWC comes with its own Certificate of Authenticity from Zero Tolerance and Rick Hinderer.
$410, $400 if you can pick up in the SF Bay Area. Feel free to call or text at 650-918-8514, I find it easier than PM.
