ZT 0450 sharpening
I have a Spyderco Sharpmaker and I'm thinking about buying the 0450. I imagine these two don't jibe with each other? The ZT angle is way less than 30 degrees?
Actually i had problem with the angle being more than 20 degrees i was kinda surprised
ZTs are ground at 20-22 degrees per side. A sharpmaker will work on an 0450 just great.
All depends who is sharpening that day.
OP, the ZT you are looking at has a fairly thick and short (height) blade which can make sharpening a little more difficult. I typically use a DMT Coarse and follow with a loaded strop, gives good results in these cases. A coarse edge is not only ideal for the steel but because of the edge thickness it will help in making a sharp edge.
