- Aug 23, 2017
I purchased a 0452 CF from knife center and it is 8 grams light of spec. Knife Center is an authorized dealer so it seems unlikely it is a clone . Any thoughts
I checked the scaleIt's about a 6% discrepancy. Probably explained by slight variations in machining and grinding from knife to knife. It's also possible your scale is very slightly off. Or a combination of the two.
I'm sure it's probably fine. It's not the first time I've hear of knives being different spec from what the official website described.[/
ThanksI'm sure it's probably fine. It's not the first time I've hear of knives being different spec from what the official website described.
Do you think that is out of spec for a ZT production knife. I checked the scale and its on. All my other blades are right on ... ThanksIt's about a 6% discrepancy. Probably explained by slight variations in machining and grinding from knife to knife. It's also possible your scale is very slightly off. Or a combination of the two.
so i guess weighing a knife is not a good clone checking strategy...Thankstape 8 grams of lead shot to the handle. . . Poof! problem solved.
How much is that in ounces?????
If my math is correct, .281 ounces or slightly less than 1/3 of an ounce.
I saw an unbelievable clone and got concernedFor th OP. Just curious. Did you have reason the believe the knife you received might be counterfeit or were you verifying all the specs just for piece of mind? If so was everything else exact?
these chinese clones are ruining the hobby. they even serialize themIf my math is correct, .281 ounces or slightly less than 1/3 of an ounce.
thanksYou purchased a production knife. Chris Reeve had every handle tested on his knives because he knew that things can change in manufacturing. ZT doesn't go to that extent, so a couple things may be slightly out of spec and it threw the weight off some. If weight difference is the only thing that doesn't measure up on you knife, then I doubt you have a fake. If it still weighs on your mind, I recommend calling or emailing ZT.
