That's the video I linked to yesterday in my post above.
EXACTLY ......... I have two 0566 and one is butter smooth assisted ............ the other is stiff as all get out.What I think djdawg is trying to figure out, and I would like to know myself actually, is how to smooth out the action and make the blade easier to flip WITH the torsion bar assisting it
You can't take it with you.Money isn't the issue for the most part. My wife and I both have excellent incomes, my problem is that I'm just super cheap. I always feel guilty whenever I get myself something. I've just always been that way. So I usually sell off a knife or two whenever I want a new one.
But after starting this thread and reading through some of the responses, I've been giving this a lot of thought. I'm gonna pull the trigger and get the XM-18. Some good points have been made such as being able to resell it for at least what I paid. And at work it would be awesome. It's a tool I would use daily so I might as well enjoy it. Currently for work I use a Spyderco Assist and it's great especially since I cut a lot of rope and seat belts etc, which is why I never spent crazy amounts on other knives cause they were always for EDC use off the job. But my Assist is simply a tool has no value to me. And it's a pain to sharpen. A really good quality plain edge would work just as well so I've decided that I will get the XM. It will be useful and I'll love it.
testosterone I seen in one of your post's you just oil to lube your knife,I have tried a few different oil's and all with the same result,I found that the oil's either dry up or get squeezed out and run away,even the Benchmade Blue Lube wasn't that great,it did make everything smooth but no smoother then the then the Super Lube Grease.
I was told y another member on this board to try Super Lube Grease and it works really well and won't get washed off from water or dry up and it is not a real sticky kind of grease that will slow that action of your knife down and it will not come off either unless washed off with some soap and water.
Just give Home Hardware a call and they can get it even if they don't stock it and the warehouse has 25 tubes right now from what my store told me because they were out of stock and had to check,here's the item number Item 8640-063
Also if you want a spare Torsion bar just email me at wadenorton2008@yahoo.ca and I will mail you one for free,mine broke as well and ZT sent me 6 of them.
The Torsion bars can brake really fast or last for 5 year's from the guy at ZT told me you either get a good one or a bad.
http://www.homehardware.ca/en/rec/i...z-Lube-Grease/_/N-1z140nr/Ne-ntc74/R-I8640063
From what I understand, you can go to the Hinderer web site and they will sell directly to you since you are a firefighter. There is proof of job requirements to send in in order to get the knife at cost. You may want to consider a wharncliff blade for the line of work you're in. It will be the only knife you'll ever need and out last any other knife you'll use. It is a name brand tool and not a bargain tool, so like all other name brand tools, you have to pay what for the quality. I'm not knocking ZT at all, I have 550's and 560's, for my line of work they're fine.
Mine is de-assisted but it seemed smooth with the torsion bar. I believe it will be hard on the fingers just because you have to over come the spring. I don't think there is really any way to get around thatIs yours assisted or did you remove the torsion bar? My 0566 without the torsion bar is also very smooth. My blade was already centred though, and when the torsion bar broke, it was not very smooth. But after removing the bar, I cleaned out all the grease, dust etc and applied some M-Pro7 gun oil to the pivot area an reassembled the knife. I adjusted the pivot screw just to the point where there was no blade play. After this the action was super smooth and was my blade was still centered.
What I think djdawg is trying to figure out, and I would like to know myself actually, is how to smooth out the action and make the blade easier to flip WITH the torsion bar assisting it. When my new torsion bar arrives, I would like try my 0566 assisted again. But there's no way in hell I'm gonna keep the assisted action if it's as stiff as when I first got the knife. It was brutally hard and my fingers were so sore.
Anyone have any ideas?
Mine is de-assisted but it seemed smooth with the torsion bar. I believe it will be hard on the fingers just because you have to over come the spring. I don't think there is really any way to get around thatI do believe the 0566 is best as a manual
My ZT0560 with the KVT Bearing system works really well and is super smooth.
testosterone the Super Lube Grease is fairly thin from what I have found and seems to stay in place and is about as slick as all the oils I have tried,it's a clear grease that seems to work fairly well and allows my knifes to flip open with about the same speed as oil.
