Thank you for the link.
That link lists annealed Ti as delivered. Can you say that the ti that ZT uses is not work hardened, solution hardened beyond the as delivered annealed state?
I have tried to work with some of the Kershaw/ZT ti - and any ti for that matter, and it is very tough stuff to drill and tap or cut.
Your own links shows that the material is highly abrasion resistant along with highly stable in terms of corrosion.
Even as delivered without any kind of treatment, you will not see grooves worn into your inner scale from the ball bearings rolling along happily under the almost zero stress application of rotating a knife blade from a folded position.
I am not sure where the fears are coming from, and I have yet to see anyone come up with an actual knife that has the problem that you are insisting is a problem.
I guess I have been lucky.
best
mqqn
^This. Plus, its not like the bearings are supporting a significant weight that would cause them to grind into the Ti.
My 0801 has been fine. I've had it 5 months. My 0770CF, however, has had a some problems. Pivot screw thought it was a merry-go-round. Loctited and left sitting for a few days and no problem. Took a lot of messing with to get it to center. I own three ZT's, 0801,0770, 0561. I used to have a 0350TS. Both the 350 and the 0770 had centering issues. No issues at all from the 560 or 0801.
PROPER maintenance is the most important part of keeping anything mechanical working correctly.
As far as Elmax goes, no issues at all. Can't say the same for S30V though.
