- Feb 24, 2016
I'm thinking of making an addition to my edc options and was hoping to get a bit of guidance from the collective wisdom of the forum. My current work edc is a Victorinox Swisstool and a Benchmade Adamas 2750. I like the Adamas, and it does most tasks I need it to do splendidly, but it does leave some room for improvement.
I'm a rancher and I'm in the process of updating and adding to my cattle water piping system. I originally picked up the Adamas after my wet multitool slipped in my hand while cutting and splicing a water line (black PE pipe) giving me a rather nasty cut. The Adamas is definitely secure in hand, but the thick cutting geometry gives me more trouble cutting pipe than I had thought it would, so I'm looking for something with better geometry but still very robust.
What I'm looking for:
-4-ish inch blade (figure 1/4" either side of 4).
-Handle shape that helps prevent hand slipping when wet.
-Robust, but still a very good cutter.
-Reliable lock, even when wet. The easiest way I've found to start the cut is to push the tip of the blade into the top of the pipe, then lever the blade to extend the cut. I don't want it folding up on my fingers while I'm doing this.
-Pocket clip is mandatory.
-Open to any sort of one hand opening style that doesn't interfere with cutting through a fairly rigid material (like thumb studs too far out over the edge to be out of the way for cutting).
-Budget of up to around $250, though less is better.
I'm currently looking at the ZT 0909 as a front runner, so info on that blade plus suggestions on what else I should be considering would be most appreciated.
