I'd rather have the S35VN anyhow...
Clearly it's 5 better. Wait! It's 5n better. This is basic algebra!
I am sad to hear Elmax being on the outs, I really love that steel. While S35VN is a lot better than S30V, lower grade steels are lower grade. That would be like getting rid of S30V and replacing it with D2, performance is close enough that most people would barely notice a difference, but the steel is just lower grade.
s30v and s35vn are definitely not lower grade steels imo.
In all fairness, I'm not under the impression the person you quoted was referring to those steels as "low grade" inherently, but "lower grade" by comparison to Elmax. Rubies are still precious gems, but definitely less precious than diamonds, etc
Does it matter, other then what's stamped on the blade? There's so little performance difference between all these materials, that it's a non issue, other than bragging rights....
Average user will not use their steels to their full potential . Zt could probably get away with using 420hc and stamping it s35vn.
I've always looked at the three of them pretty interchangably.
My exact thoughts. It is all relative. 154cm is a great steel, but compare it to S110V and it is a lower end steel. It really isn't a point of contention that Elmax is a slightly "higher grade" steel than S30V and S35VN, same as Elmax is lower grade than M390, and M390 is lower grade than S110V. I prefer Elmax, but so long as the knives aren't made with S30V instead, I can live with it. S30V has betrayed me in the past.
You can say CPM-154 is higher end than 154CM but not with S110V. They are just two different animals, extraordinary high wear for food industry vs all around conventional stainless which developed for turbine blade.
I think when people choose the word "higher end" or "better" they should specify at which task?
S110V might be better at cutting robe while S30V, 154CM, or even M390 are better at carving hard wood and most hard use because it is significantly tougher.
You know all anyone cares about is how long can I use this without having to sharpen it...
