- Dec 10, 2008
Done, thanks for the heads upedit your post LR, no deal spotting allowed
The Brute is a Awesome knife but by weilding on the BK1 to fit your needs,I think you hurt the temper of the brute that may of led to the fracture point...and if you find a BK1 and perform the same act you'll have another BK1 failure down the road......
I respectfully disagree. Looking at where the knife actually broke, I can not see how that would be due to the welding of those rings. I have welded in the past but I am no welder. Could you explain why the blade would break so far away from the welds?
Thanks Paul
is there any way you could modify the slabs, but bolting on a thin metal insert between the filed down slabs, and weld the rings to the insert, not the blade, that way, the blade stays factory, and you could potentially make several such inserts to fit a variety of becker blades.
Bladite
Hey Thumper.....
The only BRUTE I could find in the mess was the one I knew was there....Sorry about that!!!....Certainly a Trace made ARMAGEDDON would be an EXCELLENT substitute as would a TOPS version......I LOVE my ARMAGEDDONS they are industrial grade all the way....There is still a chance I have overlooked something......
BTW ain't them Seigels purty.....
All Best....
ethan
Now that sounds like a great idea though from what Thumper said the spot welds did not heat the knife enough to cause the failure. Really from the look of the pics I tend to agree. From the little welding I have done I do know how he said it was does sounds perfectly credible. More likely the guy is an ape. Forgot his own strength and beat the Brute to death, the way he probably beat that poor baboon to death.
I'm joking Thumper don't hit me
Your pic and posts remind me of a couple of bro's I've ridden with and a couple of others that I have had run ins with. Hard ridding hard living folks allLong.Rider
I did not realize you knew me, personally.
Tony,
A MachAx is headed your way.
If you are only half as happy as I am, you'll be tickled plumb to death!!!!!!!!!!!!!!!!!!
Seriously, MANY Thanks!
Jeff
