If the metal is warmed adequately and the casting metal is at proper temp, it will flow into whatever and not burn it. To facilitate casting molten metal onto wood or antler, use a pencil to blacken all the passage ways with graphite. This trick allows the molten metal to pour easier, more completely, and faster. Unless the molten metal is too hot, you will not scorch the wood. It will scorch and burn if you botch the job and must go back and fill voids in the metal, or the metal is over 680-700 degrees. Antler will start turning brownish then also. Below that, it does normally not burn even one layer of masking tape. If you pour Sterling, much caution is required because of the much higher heat being required. If you use a torch of some type to melt Sterling or coin, you always know when it's ready to pour/cast as there will be the proverbial "ring of fire" distinctly visible around the lip of the dipper/crucible. When casting molten metal, tap the sides of the object rapidly to help expel trapped air inside.
