My apologies if this has been done 100 times before, but I 'm a new guy and I can't search.
If you had $100 to spend on ONE knife to be your hunting/camping/backpacking/end of the world blade, what would you buy?
Here are the restrictions I would like to place on your suggestions:
1. Fixed blade
2. Production model available today on the market (unless you know a custom knife that meets the $100 requirement)
3. Blade length somewhere around 3 to 6 inches
Your suggestions welcome
Some of these suggestions have other very similar models in their series as well but all can be had for $100 - $110 plus shipping and some are a good bit less.
You are kind of wide open on the purpose there but here are some suggestions:
Bark River River Boat Bowie Green Micarta
9 1/4" overall. 4 3/4" 12c27 Sandvik steel blade. Full tang. Green canvas micarta handles. Brass guard. Lanyard hole. Brown leather belt sheath.
Bark River White Series Huntsman
7" overall. 3 1/8" A-2 tool steel blade. Antique ivory micarta handles. Full tang. Nickel silver finger guard. Lanyard hole. Brown leather belt sheath.
Bark River Classic Lite Hunter Black
8 1/8" overall. 3 7/8" 12C27 Sandvik steel blade. Black canvas micarta handles with nickel silver finger guard. lanyard hole. Brown leather belt sheath.
Bark River Sandstorm A Green Micarta
9 5/8" overall. 4 7/8" 12C27 Sandvik steel blade. Green micarta handle with green micarta guard. Lanyard hole. Brown leather belt sheath.
Gerber LMF II Infantry.
10 5/8" overall. 4 7/8" partially serrated 420HC stainless blade with a non-reflective finish. OD green TPV overmolded on nylon handle. Full tang with butt cap that can be used as a hammer. Belt sheath is engineered of a soft, rigid composite material to reduce environmental noise. Sheath is molle vest attachable. Comes with one strap.
FALLKNIVEN S1 FORESTKNIFE BLACK BLADE ZYTEL
Fallkniven S1 Forest Knife. 9 3/4" overall. 5 1/8" black coated VG-10 stainless utility blade. Black Thermorun elastomer handle with visible tang end and lanyard hole. Black nylon and Zytel belt sheath.
FALLKNIVEN F1 SWEDISH MILITARY LEATHER SHEATH
Fallkniven F1 w/Black Blade. F1 Swedish Military Survival Knife.
8 1/4" overall. 3 3/4" VG-10 stainless drop point blade with black Teflon coated finish. Black checkered Thermorun elastomer handle with visible tang end and lanyard hole. Full cover black leather belt sheath.
COLD STEEL MASTER HUNTER FIXED STAINLESS
Cold Steel Master Hunter Stainless. 9 1/4" overall. 4 1/2" drop point VG-1 San Mai III stainless blade. Black checkered Kraton handle with lanyard hole. Concealex Kydex belt sheath.
Heckler & Koch Tactical Fixed Blade
7 1/2" overall. 3 1/2" black finish 440C stainless modified recurve drop point blade. Full tang. Molded black thermoplastic handles. Molded black Kydex belt sheath.
PUMA HUNTER'S PAL II STAG
Puma Hunter's Pal II Stag. 8 1/4" overall. 4" stainless blade. Full tang. Genuine stag handles. Lanyard hole. Leather belt sheath.
PUMA ORIGINAL BOWIE STAG
Puma Original Bowie Stag. 11" overall. 6 3/8" stainless bowie blade. Full tang. Genuine stag handles with aluminum finger guard and lanyard hole. Brown leather belt sheath with lanyard.
Uzi Heavy Duty Defender.
11 3/4" overall. 6 3/4" bead blast finish 154CM stainless CryoEdge treated blade with sawback. Full tang. 6061 aircraft aluminum handle scales with black scratch resistant anodized finish and soft rubber inserts. Pry bar pommel with lashing holes. Black reinforced ballistic nylon tactical sheath. M.O.L.L.E./P.A.L.S. universal fastening system.
BUCK STRIDER ML TWO POSITION KYDEX SHEATH
Buck Strider ML. 12" overall. 6 5/8" black oxide finish 420HC stainless partially serrated spear point blade. Full tang. Black G-10 onlay handles. Lanyard hole. Dual position, molded black Kydex sheath. Weighs 12 oz.
