I've read a lot of posts, but remain confused. I want to make a 3" linerlock folder. I'm new to this. I seems that two steels are being recommended for relative ease of working with good rusults without having high end equipment. 1080 and (possibly)CPM 154. Which would be best to use? I have the equipment to grind, but would only be using a "two brick forge" to heat treat.
The following is what I've gathered I would need to do for 1080. Is this correct? Would the same proceedure be used for CPM 154? (If you recommend it).
1. Heat the steel to 1500F (bright red orange)
and cool to bare hand holding
2. Heat to barely over non-magnetic & cool again
3. Heat to dull black red, just under non-magnetic, cool again
5. Heat to a good red orange 1475F to 1500F
6. Imediately quench in Parks 50, pre heated to 100-110F
7. Temper in a 400 degree oven for 2 hours. Cool to room temp.
8. Repeat #7
I've then read to grind 1st before any heat; and I've read to grind after step #8. Which is it?
Thanks for any help.
8. Repeat #7
