- Feb 19, 2018
Hi
This is my first forum post. My questions pertain to heat treating 1084 properly. I have a hardness tester and an evenheat kiln. My problem is that my blades are not reaching full hardness. They test from 35 to 50 HRC depending where i test. My procedure is to put the blade in my kiln at 1475 and let it soak for 12 min. I have also tried putting it in at room temp and let it heat up but further research lead me to believe this was detrimental to the steel (lots of decarb) my edge will pass a file test once i get through the decarb. I have tried quenching in canola oil and vegtable oil (pretty sure they are the same thing) at 120 130 140 and 150f. They all pretty much yield the same result. When i quench in room temp water i get a proper 65 HRC across the entire blade. This leads me to believe the canola oil is not sufficient to fully harden the blade. My research indicates tons of claims that canola oil is all you need. Has anyone rockwell tested a blade from a canola quench? I have made complete knives using the oil and the edges seem ok. I have been using test samples that are ground flat with no burrs or sharp edges. I did try an actual blade in water and it warped alot. I dont think water is the answer. I plan to move to stainless but i would like to be able to do carbon steels as well. Any insight would be great thanks. I would like to thank Rob from knifemaker.ca for answering many of my questions on this topic already via email. I know the obvious answer is parks but I would rather invest the money in stainless equipment. Also vary hard to source in canada.
