- Oct 17, 2007
here is a guy who uses is what looks like a section of 4" pipe secured by the base w/ a flange to some 2x2s using parks.
Where do you get one of those electric submersible heating elements? Though, it is probably not necessary w/ the parks 50 on a hot day, workign range is 50-120? Though, probably hotter is better...
http://www.youtube.com/watch?v=iRA-PihJI1Qhttp://www.youtube.com/watch?v=iRA-PihJI1Q
Wow... it's been a while since I've seen that vid. Never the less the quench tank is still going strong! As for the heating element, it's nothing more than a standard electric water heater element. I just turn it on for about 10 or 20 seconds, and it easily and rapidly heats about 1 to 2 gallons of quenchant up to 120F or so. I think the biggest issue was that it was a little tough to get a water (or in this case, oil) tight seal after drilling in the element. Some high temp silicone and a little bit of "mighty putty" worked like a charm though. Just relying on the rubber gasket that comes with the element won't cut it. Now that being said, I originally put the element in to heat veg/canola oil. Parks RARELY needs to be heated, except for the occasional winter day when my shop is below 50F. A hot piece of steel would serve the same purpose I suppose.
Some random comments:
1) Making a quench tank from PVC is a bad idea. PVC melts. A 1500°F piece of steel can go right through it by accident. Nothing meltable, easily pierced, or breakable should EVER be used for a quench tank.
This was a foremost consideration when I built the tank. The simplest solution I could think of was to line the inside of the pipe with a piece of sheet metal flue pipe / vent pipe. Just cut the seams out and, coil the pipe a little bit, and push it in. Now there might be an issue if I drop the blade into the bottom of the tank, as I didn't line that part, but after dozens of quenches, I've never had an issue. Even pushing the blade against the sides of the lined tank won't melt through, as the steel is more than cooled enough after being in the oil for a couple of seconds.
At any rate, my only caveat to this design is that due to the inner diameter of the pipe and the volume of quenchant surrounding the blade, it's best suited for small to medium sized blades. I've used it for larger blades (2" wide and up to 12" long or so) and it works, but don't expect to do more than one blade per session, as the oil heats up a little more than I would like for doing a second blade.
