t1mpani
Platinum Member
- Jun 6, 2002
i call that pretty good value.
So do I. My dear hope is that Kabar has a much better run of luck than did Camillus, and thus will be able to honor that warranty well into the future.
The stuff I was referring to were the few incidents of batoning through wood where you had a blade snap at the ricasso or severe chipping. Correct technique would have saved these knives but, the point made above does still stand: how many broken Swamp Rats have you seen? The same large segment of wannabe outdoorsmen has done equally stupid things with those blades, I promise you.
Honestly, in the case of these catastrophic failures, I attribute the difference less to the steel and more to the differential tempering that the Swamp does. Now, I have a lot of extremely well made differentially tempered knives from custom makers and I love them, but the Swamp really does it correctly in my opinion; in that instead of leaving the spine and tang dead-soft they're actually spring tempered at about 50-52 HRC, and thus will not take a set when flexed out of straight (unless you go really far), yet keep the advantage of a more ductile blade body that can take twists and shocks, particularly when in extreme cold. While FAR from a "stick" tang, the hidden tangs on the original resiprine handled Swamp Rats are notably narrower than the full, exposed tang of a Kabar and yet, even in the few EXTREME abuse photo shoots that I've seen on Rats where they are--as you say--intentionally taken to failure, I've never yet seen a failure at the blade/tang juncture.
Now, in my opinion, SR-101 has a *slight* advantage over 1095CV in almost every respect as a blade steel, but 5/8" tangs not failing where 1"+ tangs do--that's not the steel, that's the heat treatment. The one caveat that somebody might want to throw in is the difference in radiusing but I don't see anything in the Becker's design that is an inherent stress riser, so it's just the difference between being hard throughout or being springy in the section that doesn't cut, just like an axe. Were the Beckers differentially tempered, however, the manufacture would be more complicated and thus the price would go up, and the that would be unfortunate because they are such an absolute hell of a deal.
Beckers are very tough, very well designed, well priced, readily available (something the Swamp admittedly struggles with) and overall are ten times the knife that the settlers had back in the days when the wilderness was a hundred times the size it is now and traveling it was much, much more challenging. I love my Bussekin knives, and I love me some Becker.
