110 pocket carry?
jazzz
Basic Member
Can any of y'all who carry any 110 in your pocket, front or back, please tell how you do it, and maybe post a pic of it in your pocket. I know I did in the 80's for a bit, but can't remember how. Thank you in advance. By the way, the new 110 LT is just awesome.
I did it for a while, sometimes still do. Back pocket alongside the wallet. Not much to it really, you get used to the weight/size after a short time. Works best in jeans or the like, office clothes not as much.
The 110 is too heavy for a pocket carry for me. The 110LT on the other hand is perfect. Same size but 1/2 the weight.:thumbsup:
I sewed a vertical seam in some of my jeans about an inch and a half away from right edge of my right hip pocket. It is essentially a pocket in a pocket. I carry my Schrade LB7 there and it works fine.
I carry my 110 or 110LT in my back right pocket vertically next to my wallet. Otherwise, it is in its sheath on my belt.
I like the little pocket slips Makael Makael made a few posts up. :thumbsup:
I normally always carry either the 110 or 112 in my left front pocket. Just feels normal to me now. Have been doing this for nearly 30 years now. There are many times that I will have a 110 in its sheath on my belt. But when that happens there is still a 112 in the pocket. But I realize that you can not always belt carry and those days i downsize and carry still in the left front pocket and add a 301 to the right front pocket. Over time you get use to the weight and when it isn't there it feels like I'm naked.
When carrying "in-pocket", I put it alongside my wallet in my back pocket. If you have loose pockets, there might not be enough tension to hold it in place. I wear Levis 569 (and sometimes 505) jeans. I also switched to a Secrid wallet which has more squarish sides to help stabillize the knife (I bought it for back pocket on other, larger knives which take up more sideways space). A trifold, leather wallet didn't keep the knife upright because the sides were wedge shaped when the wallet was full. My traditional bifold wallet would keep the knife upright, usually.
In jeans, yes. I keep the lanyard hanging out the top and it stays upright pretty well along the seam. In something loose fitting, not so much.
Tuck the knot up behind your belt and out the top, that should hold it. I’ve done that before and it worked well for me. You may need to lengthen it a little, thats all.
I stick it down in my left front pocket and it rides wherever it settles. The bolster will eventually rub a hole in the front leg.
The reason I'm thinking pocket is. Because my phone's out there now. If not, it'd be in the sheath, no problem.
