Unsure at this point, it's an hour and ten minute trip one way.You taking it back?
Does it just need tightened? My pivot screw would occasionally work loose a bit till I put some locktite on it. It's been a fantastic knife. Hopefully you get yours squared away....Well, I was in a local Sporting Goods store today.
So I caved and grabbed a 112 Ranger Sport.
I held it, opened it, and closed it. I liked it, so I bought it.
I didn't do a detailed inspection, It's a Buck Knife, I shouldn't have to.
I bring it home and I had a package waiting a Stormy Kromer Mackinaw.
So I take my new Ranger out of its box, and cut the packing tape.
I like the way this knife looks, I like the way it feels in hand,
But after I closed it I heard a noise.
This thing rattles!
When closed, the blade has so much play it hits both sides of the liner.
If I practiced I could do Morse Code with it.
$130.00+ for a Buck and I get this?
Not impressed.
Doesn't anyone care about doing a good job anymore?
If I grasp the bolsters with my thumb and forefinger, I can squeeze it and make it stop.
But man this is disheartening.
I was very excited about this knife.
I went and grabbed my Anniversary 110, solid as a rock.
I paid almost double for the Ranger Sport.
And it will probably turn out to be a great little knife.
But man I tire of issues that shouldn't exist.
LV,
Just checked mine....the pivot screw is a T10 and the rest of the bolts are T6. Pretty common sizes on knives so it shouldn't be hard to find. Like I said...I'd put a bit of Locktite on the pivot screw and you'll be set.Unsure at this point, it's an hour and ten minute trip one way.
May just try and source a wrench that fits the tiny bolts.
As mentioned above I called Buck to see what they have to say.
This was the only one the store had.
Mine is perfect in every way. That’s disappointing on yoursWell, I was in a local Sporting Goods store today.
This thing rattles!
Not impressed.
LV,
I carry mine often but I’ve only stropped it. No problem thereI've been wanting a 112 Sport ever since they came out but I haven't bought one because I fear that the thumbstuds would be in the way when touching up or sharpening the edge. Anybody had to alter their preferred sharpening angle because the thumbstuds got in the way?
I've been on the fence with these for awhile. The ONLY thing I don't like about it is that thumb stud. It looks like it was put on as an afterthought. It just doesn't seem to match the knife. I feel they could've designed it better to go wiith the flow of the knife.The 112 Sport is thicker and heavier than the Bugout but definitely more robust. I own both and carry the 112 much more frequently for the above reasons and also due to the clip point blade vs drop point on the Bugout.
As mentioned above, the TRX is more comparable to the Bugout and a great knife as well. It just doesn't deploy as well as the Benchmade.
Thank you both.I agree withhunterjrg I don't see the thumb studs being an issue.
You would have to be leaned way over before they contacted the stone.
Glad it was just the pivot screw. You'll love the knife....Update #2
Went to town this afternoon,
Picked up a precision bit set from IFIXIT, ($40.00) no one local had Torx bits that small.
Nice kit should work for eye glasses and a myriad of other uses.
Snugged up the blade and it is normal now.
27 hours in no call back from Buck's Warranty Department.
Rather disappointing.
They must be real busy fixing other mistakes.
LV,
