- Jan 9, 2011
Here is a new one I came up with for every day carry. This one is nearly 9" long and weighs less than 4 ounces, it is full sized and fast in the hand. This knife features a chisel grind with a convex zero edge, it is a slicer. I did the heat treat myself with my digitally controlled kiln. The handle is attached with West System G-Flex epoxy and flared stainless steel tube rivets. The finish is a satin style scotchbrite belt finish, you can maintain it's finish with a scotchbrite pad. Sheath in progress...
O1 Steel
4.5" handle 4.25" blade - 8.75" long
1/8" thick
Grey and Black G10 handle
Handmade in the USA - Sole Authorship
Sold!
EDIT : The sheath is finished up, it is concealex and tek lok compatible. The way I make my sheaths with the aluminum Chicago screws is very versatile, you can move the screws around and put the tek lok on either side, you can also take them off to clean the sheath. On this one it can also be used as a necker, i have cord and ball chain if you want to use it as a necker.
O1 Steel
1/8" thick
Sold!
