I bet the the average Griptillian or PM2 gets 1000x the use as the average GrismoDoesn’t Grimsmo put it in their $950 Norseman? I’d say if it’s good enough for that it’s good enough for daily use.
The angle setting of a fixed sharpener like the KME is a relative setting. The actual angle is going to vary based in the blade's width and height. You would need a digital angle cube to find out the true angle you're sharpening at.Just checked the KME. It's set to 23 degrees, so I guess you could say it's 46 deg inclusive? Trust me, it has no issues slicing newspaper. It cuts easily and cleanly, and you can "wave" the knife thru it. It's possible there are more levels of slicing paper, or others' standards are more picky than mine...
Nope. That's CPM154, not 154cm. They are in fact different compositions, and in different classes in the Blade HQ steels chart.Doesn’t Grimsmo put it in their $950 Norseman? I’d say if it’s good enough for that it’s good enough for daily use.
They’re not different compositions. CPM is powdered metallurgy. CM is not.Nope. That's CPM154, not 154cm. They are in fact different compositions, and in different classes in the Blade HQ steels chart.
Either way, not the same steel.They’re not different compositions. CPM is powdered metallurgy. CM is not.
They are the same steel. They are just cast differently. In a steel like 154CM, the only major difference will be that CPM 154 will generally be tougher due to the more even distribution of carbides compared to 154CM.Either way, not the same steel.
