Ok , I finally find time to make tracking wheel/mechanism for my new grinder . Plan is this............I will use pulley system from motor ON contact wheel . Motor is 3 phase , 2hp and 1400 rpm and with 1:1 ratio pulley I will have about 32 m/s belt speed which is more then enough . For tension I will use gas spring because contact wheel is drive wheel in same time and I don t see advantage here of ratchet mechanism ?
It s time to send this wheel for polyurethane treatment so I have two question ............WHICH duro/shore ?? hardness I need to use and how thick layer of polyurethane ? I have no idea of wear rate and durability of polyurethane used for this kind of work ? All I know is that it is better then rubber ? Thanks for any help .
