- Dec 6, 2013
Here's a bunch for trade
I'll ship priority, fully insured, you'll need to do the same
If you have limited feedback or negative feedback, you'll be asked to ship first
ALL OFFERS TO MADE THRU EMAIL, i will ignore pms
I reserve the right to deal with whomever i please
Open to trades, no balis, traditionals, limited interest in autos
1. Jimmy lile boot knife doubledged dagger NO DOT- 4" satin blade, stag horn scales, tapered tang. This is a no dot blade. Has lots of fine scratches due to sheath insertion. I have not usedm carried or sharpened the blade. May have been carried, sheath shows some wear. Beautiful blade, wish i didn't have to sell it. Comes with leather sheath- Inscribed: Hand made by James B Lile
2. Kit Carson Sm m16- 3" Stellite blade, combo edge. Ti scales, steel(i believe) lockbar insert. I've carried it three times, not used or sharpened it.No blade play in any direction, centered and smooth.
As most know, Mr. Carson passed away in the last few months. He didn't used stellite in many of his blades, this one will go up in value and desirability-
3. Crawford Hawkbill liftlock- 3.5" matte finish hawkbill blade. Frame is one piece of 440c, 1/4" thick, milled out. Extremely sharp, no side to side play, little play up(back), but it's a self defense tool, so the hawkbill is made with a little give so that when it cuts, it acts like a claw. Have carried for two days, few snail trails, nothing big. Only negative is that someone tried to adjust(?), move or mess with the thumstud, it shows marring on the lug-
4.Rmok specs:
CPM S30V stainless steel fighter/combat hand sanded to 400 grit
.220" thick
5 7/8" blade
4 3/4" handle
handle material is double layered brick red and black G10
Professionally heat treated by Peters Heat treating to RC60
Cryo treated to -300 degrees fahrenheit
Will come with custom heavy duty hand stitched leather sheath.
5. Rmok specs:
CPM S30V stainless steel fighter/combat knife stone washed finish
.220" thick
6 1/4" blade
5" handle
handle material is double layered black and OD green G10
professionally heat treated by Peters to RC 60 cryo to -300 degrees
will come with custom hand stitched heavy duty leather sheath
6. Mel Pardue Auto- 3.75" hand rubbed blade. Red micarta linerless frame. One of the lightest blade i've handled. Few marks on the blade that i caught in pics(can send more pics to serious buyer). Has not been carried, used or sharpened-
7. Fairall Model #3- 3.75" hand rubbed s30v blade. Swedge has 1/4"ish sharpened at the tip. Tan and blue g10 scales, comes with a set of cocobolo scales too. Has extra hardware too.
Detent is on the lighter side. Requires a firm push of the thumb or flick of wrist to open via the flipper tab. It can also be opened with the dual thumb studs. Has been carried 4 times, cut arm hair to test the blade after i sharpened it. Fairall no longer makes knives, so this is definately a collectible. Comes with soft carry case-
8. Crawford Shark 4"- Bead blasted blade, anodized ti frame with ti spacer. I've not carried, used or sharpened. Looks to have been carried lightly by previous owner. Very slight smoothing and a few snail trails on the frame. Very smooth openeing. Solid lockup, no vertical play, very slight play(almost flex) side to side. 95% condition-
9. Daniele Serrano folder #2- 3" satin d2 blade. All ti scales/frame. Comes with 2 blades, bothe very sharp! Ti scales have a few light marks from carrying. It has been carried, but not used or sharpened. Needs a wrist flick to open. Slight side to side play, no up or down play. One of the spacing tubes needs to be flared again, i don't have the tool. Comes with case, COA, 2 blades. Very nice and solid blade, it's too small for my hands or i'd be keeping it-
10. Custom shop tanto- 6" sage blade, .23" thick, black and tan g10 scales, skull crusher. Has not been carried, used or sharpened. 11" OAL-
11. Swamprat Taliwacker- Zombie green ceramic blade, Resiprene handles. Blade length is 7.25", stock is 3/16" 12.5" OAL. Has not been carried, used or sharpened-
12. TGLB Comp finish- Comp finish blade, red micarta scales. Has not been used, carried or sharpened. Has a few spots on it and is discolored(took pics showing). Other than that, it's in excellent condition-
13. Pork Shank- Satin blade, Mammoth tooth scales with fancy pins. Has nott been used, carried or sharpened. It's a safe queen. One of the prettiest blades i've had the pleasure of owning-
14. SOW- Special edition 2007 blade, black and green g10. Comes with a kydex/carbon fiber sheath by BuyBrown. Has not been carried, used or sharpened. I paid $800 for it looking for
15. Busse Custom Shop Satin Jack Varient- 5" sage cg blade .15", Swedge is sharpened. Tigerhide scales. Has not been used, carried or sharpened-
16. Swamprat Inficoot- Sage/tan colored blade, tan resiprene c handles. Has been used carried and sharpened. Also given a penetrator tip. Will shave. Some coating missing. This is a user! Comes with camo kydex sheath-
17. Scrapyard Mud Puppy( i believe)- 154cm blade, gray resiprene handles. Has been used, carried and sharpened. Will shave. Lots of scratches on the blade. This is another user! Comes with kydex sheath-
18.Swamprat Vex- Black cg blade, black and tan g10 scales. Has not been used, sharpened or carried. Very pretty color combo, great little blade. Blade is 4 1/4", OAL is 8 1/2".-
19. Swamprat Battleguard- Black cg blade, tan resiprene handles. Has not been used, carried or sharpened. The edge does have a few spots on it.
Extremely rare blade. Comes with spec ops sheath-
20. Swamprat RMD Proto 1 of 13- 5 1/4" green ceramic blade with black paper scales. Unused, uncarried and unsharpened. Comes with a armorall leather sheath for a Busse SJTAC. Not the best fit, but it does work-
4.Rmok specs:
.220" thick
5 7/8" blade
4 3/4" handle
5. Rmok specs:
.220" thick
6 1/4" blade
5" handle
