Gorgeous blade! Time to let the chips fly! It dont have to be razor sharp to get the job done.
From my experience (and others'): it's possible that during the buffing process the edge overheats - this results in usually less than a mm of softer steel, that the first or second sharpening will take away and then you hit the properly hardened material. To complicate matters, during forging, from my understanding if the blade has been overheated, the metal loses some of its carbon content (along the edge) - this process is called decarburization. Thus, this second aspect concerns the satin-finished knives as well. This usually results in very very small edge rolls that should go away once you get to the thoroughly-hardened core, and is not the same thing as a heat treat failure.
Now, I initially thought that this could happen only in custom blades, but I read Cliff Stamp saying that he is usually reserving two or three sharpenings before he makes up his mind about a knife, as production blades might present the same issue.
This is from my research on this forum and others, someone please correct me if I am wrong in any detail. I can see why an annealed through buffing or decarbed edge would wear off quicker, but this should become a non-issue.
I would rather be curious if anyone here managed to sharpen his kukri enough times to get past the hardened metal into the springy, softer steel behind it. I know edge lifetime can be preserved through steeling with the chakmak but sometimes you do need to take material away, no way around it.
The Kamis are well taught and well experienced blacksmiths, particularly with khukuri. They are taught by their fathers, as their fathers were taught before them into time immemorial. Most have been learning about it since they were old enough to walk and understand the teaching given. Most, by the time they are 20 years old, are at or near master-craftsman level in teaching even if their workmanship level isnt up to that par. Himalayan Imports hires only those with the best workmanship as kami. Others are hired as helpers and given the chance to learn better craftsmanship.
That's the way most true craftsman teach apprentices. You start by sweeping the floor and watch, watch , absorb, learn, watch some more... And maybe in a few years you get to pick up a hammer. All good shops teach in this manner in my opinion. The masters don't want to give there secrets and tricks to just anyone. They want to know you have a passion and true understanding of the work it takes to get the job done.
