Already posted in the picture thread but I got #34 the other day. I'm still holding off till I find out if anyone wants to swap with me for one with the thinner flatter handle material before I mess with it, but if I end up keeping this one there are several things to be fixed before it'll get carried, but carried it will get. I like to carry a small traddy for the little stuff and sheeple friendliness all the time. Like T. Erdelyi posted, all three blades are a tiny bit overheated at the tips. Also the main blade is a little unevenly ground, almost like a recurve, it's slight but it puts more belly towards the tip than I like, so I'll take that down a little thinner towards the tip to make it match the blade up by the tang better. And the last thing that bothers me is 2 of the tips are above the handle material when closed (my Canittler had the same problem last year, I guess I'm just unlucky) The main blade is raised about I dunno, 3/4 to 1 mm above the scales, just enough to catch the pocket. And the warny, which is hidden when closed anyway, but makes the knife taller in the pocket, the warny is a good 1.5 to 2 mm, to high. Just odd, easy to fix and all, but just odd. Luckily all easy stuff to fix, and some of it is personal taste, like the height of the warny, so like I said I'm holding off till I see if anyone has a thinner handle and wants the little bit more bulged material.
Syn
