waynorth
Dealer / Materials Provider
- Nov 19, 2005
first thing I did was round all the steel edges so that It rode nicely in my pocket without snagging or excessive pocket wear. I also added some green compound to the spring/blade sliding joint so that they would "lap in" and smooth out a bit more quickly.
I've been on the verge of trying to change mine from a two bladed model to only the Wharncliff. I just can't figure out how to undo the pins. Do I just attack them with a center punch, or do I need to remove the head of the mushroom with a drill or dremel? Also, any tips on how to locate the pivot pin since it is so nice and polished. I've searched for a traditional disassemble / reassemble thread, but the best I've come up with is an exploded parts diagram and the GEC works in progress pictures.
The best way to disassemble a pocket knife, without marring the surfaces is to cut the pins!
I have a worn but sharp old chef's knife, with a thin blade, and I tap it through the pins. It will slip between a blade and liner, with persuasion (small hammer). Then you can easily tap out the pins from the inside if you set the "halves" over a hole in an anvil with a heavy protective piece of leather.
Drilling the pins will screw up the drillings in bolsters etc. This cutting method - a standard procedure BTW, keeps everything intact. Of course you have to keep the knife straight and upright, and take care not to gouge the liners.
Hey, this is fun. I can't wait to see what else can be done to personalize one's forum knife.
