- Oct 26, 2010
Gotta get me one of those! with Micarta inlays, that is.
It's the same pivot as the Umnumzaan so it can be too loose or tight. It needs loctite to keep its place. CRK uses a relatively weak purple loctite and that's all it needs.
Can anyone confirm that the pivot on the 25 needs Loctite to stay adjusted?
My 21s and Insingos don't.
With the Umnumzaan, Loctite is necessary in the pivot assembly. The threads in this assembly are machined to very close tolerance; the drop of Loctite gives additional rigidity. It also prevents the pivot from backing off. Loctite is an accepted engineering screw retention substance used in a wide variety of industrial applications including medical, electronics, automotive and aerospace. We do not “glue” our knives together. Extensive thought went into all aspects of this pivot assembly – it did not happen by accident.
Your 21s and Insingos do not use the same pivot system.
The Umnumzaan/25 system is designed to be used with purple loctite in the precision threads.
While CRK has not posted about this regarding the 25 (yet), he has spoken about the Umnumzaan, and the only way to properly put these together, is with loctite.
Here...
http://www.bladeforums.com/forums/showthread.php/682319-Umnumzaan-Loctite?p=7369833#post7369833
And in this thread....
http://www.bladeforums.com/forums/s...Chris?p=8066017&highlight=loctite#post8066017
Pay special attention to this post...
http://www.bladeforums.com/forums/s...za-Pivot-Construction?p=10333912#post10333912
The newer Umnums don't require the tool nor does the 25. My guess is that the original Locktite is good for a lot of cleanings judging from the number of posters saying they never use Locktite and the difference between purple and the readily available, blue, is minor.Thanks for that research, Tripton.
But a folding knife that requires a special tool AND a Loctite that's rare and difficult to find? Or the knife's pivot will continually loosen?
I don't get it -- what am I missing?
It interests me why someone would spend so much money on a knife and not follow the manufacturers recommendations but it is your money.
I would hazard to guess that the reason Chris stopped using the Sebbie bushing and washer system is that the washers and bushing might need to be fitted to be replaced. If you exchange blades, a new fitting might be required. If you ruin a washer, it might need to be re fitted. Wear, personal preference on how easy the blade should be to open etc. were not easily adjustable. With the new system, parts are totally interchangeable and wear or personal preferences are easily adjusted to perfection.
Many thanks for these responses. That's why we come here.
That said, designing a folder that requires Loctite for the pivot to stay in tune does not make sense to me.
Do you take Loctite with you in the field?
:thumbup: well saidDo you disassemble your knife in the field?
Why?
There is no reason at all to be disassembling these knives in the field. The open back construction allows easy cleaning of debris, and tight tolerances in the pivot keep things out.
Frankly, I do not carry tiny allen wrenches with me "in the field" anyway. Anything that the knife goes through that would require a complete tear down will wait until I get home.
As far as designing a knife that "requires loctite for the pivot to stay in tune", well, I guess the same question could be asked of all manufacturers that put together screw together construction pocketknives without a pivot bushing...because every single one requires some kind of threadlocker if you want the pivot to stay put.
I wouldn't but the recommended solvent is Locktite 768. I have used acetone to clean up the blue. I suspect the purple would be similar.What method is recommended to remove the loctite from the female side of the screw?
