I already have a GIB and 9" disc so I just wired in a switch and run all 3 machines off the same KBAC VFD.
It was a lot cheaper than a comparable Bader as it turned out Brett needed plumbing work and that is what I do for a living so I traded him my labor for part of the cost.
Even wo the labor discount it was several hundred dollars cheaper than a Bader including the horizontal tilt. Honestly, I think his grinders are underpriced so they are a good value for the money.
Can you shoot me a pm/email? I would love to chat about how you did this as I plan on doing the same thing...
In my opinion if you want a horizontal grinder, there are only 2 main ones to consider in my research - the Wilmont TAG or the TW90 - both flagship products as stated.
I just ordered a TAG-101 package C after much internal debate and turmoil lol. I have called both Travis (Wuertz machine works) and Chris (Wilmont grinders) and spoken at length with each. They were both very helpful but I did notice that Chris seemed to be more on spot about returning calls, also he will have me set up quicker (less than a week to get the grinder in hand) vs. 4-6 week wait on the TW90. Plus I am going to drive up and get it since it's only 1 state over
As stated you can go wrong w/ neither, there are some features about the TW90 that I like better (it was built from the ground up to be on a rotating chasis, the small wheel attachment is sweet, the ratcheting belt tensioner, etc), but in the end I think the TAG will fit my needs a little better. I really like that:
- the TAG's platen rotates, the tool rest arm is just amazing and much more versatile than the TW90's imho (for example, you can just rotate it over and use one of the 2" contact platen wheels for contouring if you want)
- it's got the three arm inserts for broader applications - I can use an 80" belt and have 2 contouring wheels set up at one time
- my existing contact wheels fit (1/2" arbor) - to be fair, Travis stated he could do a mod to make these compatible on his machine also, very kind of him.
- my small wheels are compatible already (the ones from USA knifemaker) - only problem w/ these wheels is that you can't do fuller work I don't believe
- it can take a 14" contact wheel no problem - for the TW90 Travis would have to get you a different arm to make it work
- Travis' KMG SG attachment will work with the TAG as well if I need it to, but I will probably just end up getting a used SG for cheaper and converting it to belts - Chris was very helpful here and is more than happy to work w/ me on getting this set up
- It's cheaper, even after getting everything I need (3 contact wheel arms, small wheel holder), no by much but a few hundred dollars or so is nice to save!
I was really torn to be sure... the TW90 is an exceptional piece of equipment but in the end the TAG is what I went with!
