I'm dying to see a picture of it tilted. Any chance you will post one?
Definitely. I want to get my first batch out for heat treat, and I don't have an immediate need for the tilt (I already have a 9" disc for rough profiling), so I figured I'd work the tilt mechanism or stop when my first blades are out for HT. I also need to come up with something for small radius profiling, because a quick-change tooling head and rollers isn't in my budget unfortunately.
I went over to pop's hardware emporium and found a couple of air cylinders and a couple of air springs I was keeping over there, so I am going to be playing with those while I'm waiting on HT.
I definitely plan to redesign the tilt mechanism, now that the grinder probably will be staying on a stand. I've had some medical issues, etc. pop up, and my full shop with stationary tools seems to be farther and farther off every day. I still love the idea of a semi-stationary base with a work surface and storage, but for now that's going to have to go under the "I'd like a late model corvette" category.
I tend to do this a lot on first drafts, I'll try and design something in ten different directions to satisfy all of these variables, and then find out it doesn't satisfy the one variable I end up needing it for.
I did test it with a piece of wood as the stop, and it seems to keep its tracking and everything, so at least I'm good there. It is heavy, when all the way tilted down, but when upright it is pretty well balanced, so it gets easier to tilt the closer you get to the latches. I may just use a simple stop until I redesign the motor mount/tilt into a single bracket.
