- Sep 17, 2012
Hello BladeForums!
USA trades only. It is your responsibility to know your own laws, especially pertaining to autos.
All offers are welcome, although I don't have any particular interest in balisongs, OTFs, or traditionals.
Please send offers through email or PM.
If you would like more pictures or have any questions don't hesitate to ask.
The knives!
Rebladed Emerson Commander. Used but in solid shape. One of a kind! It has an m390 blade made by Reese Weiland and was later shaped to its current state by Charlie Mike. The blade is thicker than standard Emersons so it does not have room for any washers. Still opens smoothly though. I can easily thumb it via the wave hook. The tip is rolled a little bit but it will sharpen out (I'm not skilled enough to mess with higher end steels). Some marks on the g10, pivot screw and the clip. Locks up solid with no blade play. The lock will stick a little bit when waved. The blade sits a little towards the clip side. No box nor the original blade/washers.
Click HERE to see comparison spine shots and measurements of the Commander. They're in post #7.
Backwoods recurve fixed blade. Lightly used. I believe it is made out of 1095. .15 thick. 8.5in overall with a 4.25in blade. About 4in of cutting edge. Very light patina. Not sure what wood the handle is made from, maple perhaps. Lots of character though. Sits in an attractive, tooled leather sheath.
Microtech Mini Socom Auto. Used. 1998 model. Has a few pretty good dings in the aluminum but that's only cosmetic. Other than that it's in very good shape for it's age. Sharp and centered blade. No blade play. Fires fairly hard too. No box with this.
Protech TR-3 Integrity. Used. This is the manual model with titanium handles. A good amount of snail trails on the handle and clip. Centered with solid lockup and no blade play. Still pretty sharp. Comes with the box.
Larry Withrow liner lock folder. Used. Good looking san mai blade but has some scratches on it. Fairly sure it's centered, if not its just a touch off( will confirm later) with solid lock up and no blade play. On the backside, the detent hole peaks out from the scales. Anodized and slightly jeweled titanium liners. Blade rides on bearings and is very smooth when opening. If you disengage the lock and try to let the blade fall, it will only fall about half way then stop. Not sure why. Besides that it has nice action. No box.
Alan Davis Damascus TI frame lock. Used but in good shape. Damascus blade is fairly sharp and is nearly centered(will confirm later as well). Solid lock up with no blade play. This rides on bearings also and is extremely smooth. Comes in a padded case.
Pictures in the next post.
The knives!
