In case you hadn't guessed, you stepped into a hornets nest! As a newer maker, I was all set to triple quench, cycle in the freezer, etc during my first hardening attempt. Mostly from reading the mag that shares a name with this forum, nothing like a secret/special method for someone new to a process. The man who writes those articles is highly respected and deserves that respect. Luckily I realized my steel was different from his and the methods only applied to the 5xxxxx series before I made any forum posts.
Many have been able to duplicate his results, many more have not. From what I can tell, the science may support further grain reduction from a triple quench but it can't fully explain the reported benefits of the triple quench process. Benefits that some very respected folks have been unable to reproduce. Only time will tell, maybe science will catch up and end the controversy.
In the meantime, I plan on trying the triple quench only after I have a repeatable single quench process for 5150/52100. I will make up my own mind then. And that may never happen, I am having too much fun with hamons to stray away from shallow hardening steels.
For the record, we owe the man who writes those articles a debt. He was and is a pioneer in our craft and has freely shared his knowledge and advanced the art of knifemaking. That said, he is repeatedly pushing a controversial heat treatment regime as accepted practice in media where beginners pick up on it and apply it inappropriately. He could be more clear in the articles that his methods and results apply only to the steals he uses and should be attempted only after a standard heat treat has been mastered. This new maker confusion causes stress to other forum contributors who are constantly having to correct the missunderstandings of beginners when they turn to a forum for help.
Well said, BFrancios. I agree with
almost everything you said
. I advise that any new makers take the time to learn about and understand the basic principles of metallurgy and material science. That will filter out most of the misinformation and wizardry.
I just tried a 52100 blade HT last week. I did a triple normalization without quenches, 1600, 1450, 1200 then 1475 for 10 min, quenched in Maxim DT48, 400f temper. The tip didn't harden, and could be bent over with my thumb. I was more worried about overheating rather than underheating the tip, and the color going into quench was uniform. Redid the 1475 for 10 min, into the Maxim again, made sure it was at room temp, then stuck it in the freezer overnight. Tip is now hard. I "think" I didn't quench long enough the first time, and the heat retained in the blade left the tip soft, and going into temper without fully reaching full hardening, added to the problem. At that point the tempering colors were all over the map. With the freezer cycle between the quench and temper, the temper colors were quite uniform. What do the more knowledgeable people think happened?
Willie... what is your heat source. The fact that you said you were worried about overheating the tip, leads me to believe your were using a forge or dare I say it... a torch. Another statement you made about tempering colours had me raising my brows as well. The oxides produced during tempering is a notoriously bad indicator of temperature. Mine come out with all sorts of funky patterns at times. What are you tempering in?
For the record, I do not quench on the first normalization cycle. Here is my standard formula for 52100
1650F, air cool to black
1500F, oil quench
1450F, oil quench
900F, air cool to 400F, water quench
900F, air cool to 400F, water quench(yes, again)
Grind, file, drill, etc...
1200F, air cool to 400F, water quench
Heat slowly to 1475F, hold for 15-20mins, oil quench
Temper at 400F for 2hrs, check hardness (bump up temp as needed and repeat last heat for desired hardness)
Final quench and tempering temperatures do change a bit, depending on the steel but this formula would work for just about any high carbon non-stainless steel. L6 and a few other steels need more TLC to make life easier.
