- Nov 23, 2013
This evening I was post HT grinding on a few 1084 blades with a 3M Cubitron 977F belt in 120. The belt was pretty much at the end of its life, or so I thought. I was just about to change it when I decided on a whim to use the spray bottle of dish detergent and water on the belt, sort of a "damp" grinding. Lo and behold, it revived that belt back from the brink of death! It seemed to grind as good as a belt with 3/4ths of its life left in it. I finished my 120 grit grind on two 4" hunters with that method, and it seems to be at half life- about where it gets relegated to pre-HT work.
Can someone explain what is going on here? Ive tried the damp grinding method with just water before, and seen negligible difference. The soap water also seemed to keep the blade cooler as I ground than dipping the blade or spraying water on the belt does. Is it the soap reducing friction, thereby reducing heat? Is it extending life of the belt by helping carry away swarf that would otherwise end up embedded in the surface of the belt (similar to using an oilstone dry vs. with oil)?
I know the usual knifemaker mantra is to "use belts like their free", so I'm wondering if I'm wasting my time with this. After seeing the results tonight, I think not. What do ya'll think?
