HSC///: I believe Kuraki explained what was going on with my belt very well. This belt was the first belt used post HT for 1084. The blades have a bit of baked on oil with the usual scale and decarb. I am quite certain that it was a case of gummy swarf clogging a belt, causing it to cut poorly. I think that the soapwater loosened the swarf, exposing the still sharp ceramic abrasive beneath it. Kinda like using a metal hacksaw blade on softwood. It cuts poorly because its teeth are plugged up with sawdust, not because the softwood dulled the blade.
Also, the consensus seems to be that wet grinding cuts better, but water alone does not "stick" to the belt well enough to be of much help. Maybe I'm totally wrong, but this answer seems to make the most sense.
ah ok, very good
do you use the rubber belt cleaner stick?
have you tried that?
