This picture shows two men working with a sharpening tool and a swors, they are grinding out a fuller or polishing the fuller.
You can se the tool they hold in their hands also help them to hold an angle. The same tool downside part of fabriks or leather can be changed to parts of wood when they sharpen the edge and with those part can they hold a very exact angle.
The antler beside the grinding table holds quarts sand and fat. They have different grits of quarts sand and can go finer and finer during the sharpening process.
English is not my languish. I translate directly from Swedish and describe as we talk in Swedish.
My English is also limmited as you can se.
A convex edge can be meassured in degrees - as in the part of the circle L. We do so here.
Most people do not know how many degrees their convex edges holds ( or even how many degrees their edges holds).
As I wrote above, FK holds around 6 degrees steep convex edge and Bark River use a flatter convex sphere on 2-3 degrees. Both are convex - but there is a very big differance innthwir performance.
People still think that convex is just convex. It is not so. A flat edge is flat in different degrees and it is simple to describe a flat edge and its degrees. Also if the edge have a secondary bevel.
The problem is that it is very hard to describe a convex edge correct becouse we have to describe a curved part of the edge - and also how many degrees the apex holds (the cutting edge).
I can not describe my convex edge so exact that you can make exactly the same convex edge on your knife. Most people can not meassure a convex edge - and my experiance is that most people who owns a FK dont knows their edges.
A normal edge in US are around 40 degrees total. A normal edge in Scandinavia are around 20 degrees total = we have different knife culture.
My forest axes have convex edge on 35 degrees. My splitting axe for firewood holds 45 degrees.
A standard Mora knife have a 11 degree edge + a very thin secondary bevel, nearly noy visble, in 2-3 degrees. The total edge for a Mora knife is then 26-28 degrees.
I use a chopper when I am outdoors, a chopping knife with 20 cm long blade, convex edge with 26 degrees on its cutting edge.
I hope that I have been able to answer your question so that you understand it, if not, learn swedish and come back yo me .
Thomas
