Nothing in math says you can measure the angle of a convex edge, only the tangents (straight lines) of those edges, and those tangents are not anywhere close to the actual convex edge.
If you look at point D as the apex of a convex blade edge, you might be able to get the gist of the discussion. The convex edge would be the green and reddish lines to northwest of point D.
Lines BD and CD are the two intersecting tangents at the apex of this convex edge. The angle of the tangents at the apex is 90 degrees. That angle is not the angle of the curved edges, it is the angle of the tangents. The tangents are straight lines. You can measure angles of intersecting straight lines. You cannot measure the angles of curved lines, although you can measure the angles of their tangents. But the tangents are not the curves lines. A convex edge has an infinite number of tangents and all have different angles. The angle of the tangents at the apex will be one of those angles.
Of course, you can describe a convex edge mathematically. No one has said you can't.
But the tangents are two straight lines that, in the case of the apex, touch the edge at only one point.
The method you are describing would say that this convex edge is equal to a 90 degree V edge, even though it is perfectly obvious that the convex edge in this diagram is much more acute than a 90 degree V edge. You get to this assumption by saying tangents are the same as curves lines, which is obviously not accurate.
People misuse math to say that convex edges are superior to V edges. They are not. Intersecting curves do not have angles. Their intersecting tangents do, but not the curved lines themselves.
A V edge can be identical, for all practical purposes, to a convex edge. The lines of each would overlap except that the convex edge would curve out by the width of just one atom, making it identical for practical purposes.
A V edge can be more or less acute than a convex edge. It can have more or less metal behind the apex than a convex edge.
The problem is that all convex edges are different, and we have no easy way to know what we're dealing with and no easy way to compare them to V edges. To say that convex edges cut better or hold up better than V edges is nonsense. They may do those things or they may not.
So, no longer avoiding the elephant in the room, Bark River often convexes the entire blade profile. This is considerably different than a convex edge.
Really good read a bit above me in some places but I'm following along
There was another video where Mike talks about their "special" convex process. They flat grind the blade (what angle and what thickness i don't know) then they convex the edge then they add additional bevels to convex the entire primary grind then blend the bevels together into one large bevel.
I believe what he's saying is they facet-grind the blade to have more control over the specific curve of the convex, then blend those bevels together. That's really the only way to grind anything resembling a consistent and repeatable convex without some sort of automation involved.
That makes more sense. I wonder if that is actually being done
I'd be astonished if they weren't mostly done by hand/eye on a slack belt.
That is what I thought they were doing. I still have a hard time believing that they will facet a profile then round it off.
Because faceting is time consuming. Many more steps to grind out the blade. When you are making thousands of blades that time matters. Also, I looked on youtube and found a video that explains that they are using a slackbelt and grinding spine to edge in one process. starts at 2:15 min in
It's in no way more time consuming. You're still removing the same amount of metal...
Also, you don't really think they're showing the entire process of grinding the blade in that few seconds of film, do you? While it's possible that they do full-height grinds in one step, I find it extremely unlikely and kind of a sloppy practice because you'll have a much greater degree of variability in doing that than faceting and blending, which--due to human error alone--is already going to have a fair amount of variation piece to piece. In fact, slack-belt grinding is slower than faceting because a backing surface allows the abrasive to bite deeper instead of the belt deflecting under the pressure.
I did. And it's not necessarily two different grinder setups. I flat and slack belt grind on the same machine without any adjustments needed. I have a slack belt portion both above and below the platen on my grinder. At any rate, it's pretty common practice to do full height convex grinds by faceting and blending because of how much more control it gives you over the shape of the convex produced. The resulting geometry is no less of a convex at the end of it, but the result is more consistent side to side and piece to piece than if not doing it.![]()
