Jerry Hossom said:
...you have no idea what I do
This is based on the cutting work done in the various reviews. Which for example is almost the complete opposite in style of what Boye tends to do which is almost all pull cuts. Same as most of the ABS guys and others who do a lot of draw rope cutting, they don't go to very high polishes. Last time I checked with Kirk about the competition sharpening, the edge there has teeth as well, and again a lot of that is draw cutting.
...that would also apply in some degree to ANY steel
Sure for push cuts, the opposite is true for slicing/draw cuts. Mike Swaim bought this out over a dozen years ago on rec.knives, he mainly worked with files first, but later extended it to rougher stone finishes. That was when I first read of his work, and it was *old* news by then as Joe has long since FAQ'ed it. He later quantifed it with some numbers extending Mike's work.
The issue gets a bit complicated based on how you define those cuts, for example if you "draw" a blade down though a piece of bone, the actual cutting is done on a push even though it is a draw cut as micro teeth on an edge can't readily saw into the bone, they will just get deformed. Thus again a high polish works better, same for soft metal cuts.
So if you wanted a more rigerous statement it would lie along the lines of "as the media gets soft/open enough for micro teeth to saw it, the cutting ability and edge retention will increase with the roughness of the finish".
There is a stopping point at which you lose gains however, I usually use 100 AO, Chad has said that 80 grit AO works even better, I have tried really coarse 40 grit ZO and that would not cut all all, the individual teeth were no longer well formed.
-Cliff
