- Apr 1, 2004
Why is it that 420HC receives a fair amount of praise on this website, while 440A is often looked at with disdain and contempt?
Thirteenth Star said:Why is it that 420HC receives a fair amount of praise on this website, while 440A is often looked at with disdain and contempt?
GoodGuy said:I would speculate that 440HC is often praised because of Buck's use of it. The 440HC that Buck uses is well heat treated, and it is used in high quality knives.
ginshun said:Neither one is what anyone should consider a high quality steel.
I think that the main reason that 420HC is more respected is because Buck uses it extensively and puts a really good heat treatment on it, and thus producing a knife that is inexpensive and still has a reletively good edge holding ability.
440A is pretty much the polar opposite. It is generally used by companies that make cheap crappy knives that you buy from a Bud K catalog for $2, and its heat treat is crap. It holds an edge good enough to slice through an apple, and then needs to e resharpened. What do you expect for $2 though?
Now this is not to say that no reputable companies use 440A, as I believe there are a few that use it on occation, but it is pretty uncommon.
Buck uses 420HC with good results. Also, it should be noted that SOG uses 440A on some models with good results
Kershaw uses 440A on a lot of their knives, and I wouldn't call them cheap or crappy at all.
the possum said:I think they're both crap.
Ahhhh. Feels good to get that off my chest.
I grudingly continue to own and use knives in both steels since I can't afford to replace them right now, but I have never been entirely happy with their performance. Some of us just have different definitions of "good".
Blackhearted said:i have a couple of 'cheaper' knives simply labelled '420' or '440 SS'. i am assuming that the 440 SS is 440A? what is the 420 then?
cheers,
-gabriel
Again.. aus-6 IS a european copy of 440-a,, aus-8 440-b, aus-10 is a 440-c equivelent. ats-34-154-cm virtual twins. only a few changes for machini ability. 440-a and 420are both too low in carbon content to effectively take a decent heat treat. Its done by cheating the steel. very similar to what was done in the olden days to make cheep cold rolled steel perform, In the old days it was case hardening. the modern method does the same thing. Hard outside soft interior. sharpen enough and you find the crap. Cheap is cheap Price wise and quality wise. You some times get what you pay for, sometimes not. Greed is running rampant in the knife manufacturing buisness, just like everywhere else. Crap sells. Just advertize well, and put a high price on. it. The kershaws, Gerbers are not the same knives they were before Peet's and Kershaws death. Period. M. LovettWunderbar said:I really like the 440A that my Gerber Mark I has. It does not stain easily, it sharpens well, and it is very tough. It's too bad that many cheesy knives are labeled "440 stainless steel" when they are not really 440A at all. Even big name companies like SOG used to call their AUS-6A steel 440A. I was told that "440" is used to describe other types of generic stainless steels for marketing reasons. I think that real 440A is a great inexpensive steel for the price. One thing that another forum member mentioned was that Buck uses 420HC over 440A because 420HC is easier to machine? I'd like to see more comparisons between the two steels.
Just...HOW? How do you even find a 15 year old thread?If one were to hack saw one of these cheap blades long ways in two would you be able to "see" the soft crummy innards? I might try that, but I might feel guilty as well.
