Tim the Wizard
Street Samurai
- Apr 21, 2012
Solid, honest work.
Hey Justin, what caused the rust under the scales for you?Nice. I’ve had similar on D3V under the scales as well, though less severe. Blade itself looks new still. Slight darkening when compared to a pristine example.
Looks like 4V isn’t too bad at all. Thanks for taking the time to write this up.
a film of Boeshield under the handle slabs is a good way to ensure no corrosion sets in there
boeshield is boeshield, so far as I know. It was formulated their landing gear from corroding and is wax based
@Casinostocks
They are for me. I just had to reload the page. They did not work the first time I viewed the page.
Ah yes, I forgot to add those little details...But how did it cut/perform/retain the edge? How do you touch up the edge....or even need to?
The edge held up nicely. A toothy working edge (DMT Medium) would last easily until lunch without significant noticed degradation and by the end of the day would have me stropping on cardboard or hitting a steel twice. A higher polished edge (DMT EEF), would last until lunch with needing a quick cardboard strop once or twice, then two or three times on a steel/cardboard.
Don't take my comments as meaning the edge was "dull", it would still cut fine, working edge, but fine. I am just Very particular about my edges, so I tend to be a bit fanatical when it comes to feedback from my knifes edge.
One of the primary reasons that I chose this knife is that though not likely to corrode as quickly as some other alloys (1095 for example), it is still prone to corrosion.What motivated you to use 4v in that environment, as opposed to something traditionally more corrosion resistant?
I have only used 52100, 1095, and 1084 in a similar role, though more beef was contacted. Ranked in terms of:It sounds like you can make a more acute edge on the 4v. Have you you tried 3v in similar circumstance, and have you noticed any substantial difference in durability/edge retention with your level of daily use and care?
