5 to choose from.
benchwarmer380
Valyrian Member
Platinum Member
Feedback: +39 / =0 / -0
Good day Blade Forums I have some knives to trade.
I have a Buck 110. It have some scratches on the blade and the brass could use a polish. Solid lockup. Not quite centered, it slightly favors the left but it doesn't rub. Still hair popping sharp. Pouch, but no box.
Cold Steel American Lawman. Solid lockup with no play, but slightly favors the left as well with no rubbing of the G10. I have sharpened it a bunch and still cuts adequately but I'm sure someone else could improve upon it. I also sanded off most of the paint on the blade as well as the lock bar, back spacer, pocket clip, and spring. Even on the inside. I also sanded under the pocket clip so it doesn't shred pockets. With box.
Beretta Avenger. Lightly used but it great condition. Still pretty darn sharp. Mirrored bevels and backside albeit a little foggy but still clear, if that makes sense. Centered with solid lock up. No play. Comes with the box.
Traded. Benchmade Mini Grip. I received it BNIB which it was, but it came with the worst factory edge I've seen. Almost no bevels and fairly dull. I put a decent working edge on it and only carried it once. The only things it's cut is paper to test while sharpening. Two tiny dots of paint worn off from the clip but hardly noticeable. Solid lock up with no blade play. Box baggie and papers.
Last is a new Hard Edge Knives Little Squall. Only tested sharpness on some ARM hair which it removed eagerly. I've kept it oiled but there's a couple of spots of patina on it. Florida humidity will do that. It's a sweet little knife ready for work. Sheath but no box.
Email or PM offers, questions, or requests for additional pics.
It is your responsibility to know your laws.
Open to all offers. Would prefer to trade even or up but multiples can go either way.
Here's a list of what I'm most interested in no particular order.
Grayman Dua
Spyderco Southard, Caspian Salt (pointed tip) Cru wear or regular Military, Citadel
Protech autos
Small Sebenza with a blue stud, Insingo preferred
Becker 15 or 17 or similar fixed blades.
Emersons
Kershaw Damascus Shallot
Boker Kwaiken preferably with the flipper mod
CRKT Heiho or Hissatsu plain edge
