- Sep 10, 2010
Hey guys,
I have up for grabs 3 Fell Beast Bolo machete blanks. These are left overs from the previous run that I misplaced in my shop and just discovered. Because they are the older iteration I will be selling them at a reduced price.
The only difference between this iteration and the newer runs is that the very front of the handle where it turns into a guard to prevent forward slipping is a little more pronounced. Otherwise these are exactly the same as the newer runs. These are the last Bolo machetes I have and I will not have any more in stock for a couple more months.
These blanks come fully sharpened so make sure to cover up the blade you are working on it!
The tang holes are 1/4th and 3/8th for the lanyard. I can supply you with stainless tubing, corby bolts, or micarta pins. I can also supply with handle material at cost if you would like . If you are buying your own scale material I recommend 6.5X2 in blocks at least 3/8th thick.
Here's the specs and a quick write up on this style of machete.
The Fell Beast is a new hybrid breed of machete that I've developed specifically for use in hardwood forests where extreme durability is required and failure is not an option. It is a heavier, more powerful machete designed for everything from clearing blackberries to felling hardwood trees. They are extremely tough, fast in hand, and with proper technique, will out chop any tool in its weight class. Made from 52100 steel with a spring tempered spine and 58RC edge, these will hold up to extreme use where other machetes chip, roll, or suffer catastrophic failure.
Steel- 52100 with spring tempered spine and 57-58 RC edge
Length- 23.5in overall
Blade Length- 17.5in
Width - 2.8 at the widest point.
Thickness- .108
These are $129 shipped and paypaled CONUS. PM me or email me at huntsmanknifeco AT gmail DOT com.
Thickness- .108
