BluntCut MetalWorks
- Apr 28, 2012
Thanks Don!
My 4th HT (post #10) used 1500F aust temp with short soak time, tried to get higher hardness via higher temperature and mostly kept at-quench RC by low temper temperature (2 long snap tempers).
Don - OK 1450F (3 minutes soak?), shall I perform any normalize / thermal cycle / sub-crit anneal steps too?
My view into wear resistance for Aldo current steels composition: 52100 - 0.94%C & 1.42%Cr (translate to 27 carbide per 1000 atom). W2 - 0.93%C & 0.08%Cr & 0.17%V (translate to 1.5 CrC+3.3VC). Excess Carbon not used by tempered matrix form & precipitate mostly into FeC form. Given everything else optimal, I expect/guess 52100 27 CrC be more wear resistance than W2 1.5 CrC + 3.3VC. That is in theory but perhaps botched-ht is my reality.
4th ht:
Normalised (with tool wrap) 1600F 10 minutes soak; hardening 1500F 5 minutes soak; Park50 quenched; cryo; 2x 325F tempered.
I would question your heat treatment of the W2. I haven't done any scientific tests, but my W2 blades are noticeably better than the 52100 blades I made years ago. In edge holding and toughness at higher Rc numbers... It Kills 1084 & 1095!
I've found 1450 and less soak time to give much better results. 68.5 Rc right out of the quench (Parks50) and 62-63 after two 1 hours temper cycles at 425, or 61-62 at 450.
Not all W2 is the same though. It varies widely...
