KnuckleDownKnives
Time to make the doughnuts..
- Feb 12, 2015
Nicely done!
Looks pretty darn good rub a lil wd40 on the handle to make the colors pop, and your plunges look off a bit but still a very nice job
Nice job overall! I would only suggest tapering the front of the scales and rounding the edges of them some.
Good 'un. Round aaaalll the sharp corners left on those scales.
Nice work Marc! Aside from what has been said, I would rethink the mosaic pins with that handle material, but that's in the eye of the beholder, and many may like it. Pretty impressive for an early work for sure.
Patience is surely the key to better work as you note. I found I had to really learn to enjoy each step to slow down. The rush to finish is an evil driver![]()
nice
but I see a sharp corner in the first pic that could really benefit from a radius blend
Very nice! It looks pretty good to me & yes "chasing the plunges" can be maddening when trying to get it just right. A bit more rounding would be nice for blending as was already said, but I really like the pattern you have with the camo pattern.
One thing that jumped out at me is the rear pin location. Next time can the shaping be done on the grip to put the contour lines so the center of the pin ends up at the uppermost area of that island? I think it would look good if it was sitting at the top of the mountain & not on a side.
looks good. i do not see anything in left field. just very fine points and most have been mentioned. plunges: before i had a file guide, i would carefully wrap 4 layers of masking tape around the ricasso, as a stop so i do not run 80 grit accidentally across the ricasso, and where each plunge stops will be fairly even. not as even as a file guide, but more even than doing it by eye for us beginners. i used to keep trying to get my plunges even, fixing each side trying to match the other until there was almost nothing left. i came up with this idea. i use some blue marking fluid on the edge, and mark my .025" scribes along the edge. i take a square, and scribe across where the ricasso will start. then, 1/8" or 3/16" away i make another line where i want the plunges to start. i clamp the blade in a vise and carefully scribe the curved lines of my plunges, as in the diagram. when i grind starting with 36 grit, i stay totally forward of the plunges. when i switch to 80gr, i grind just a little past where the plunge curves start. when i go to 120gr i sculpt the along the line, but leave the line there. after HT i can usually still see the scribe lines, if not they can be scribed on again and grind right to them, then smooth any bumps when i go to 220gr. this has helped me not grind away my plunges to nothing trying to get them even, maybe it will help you.
The scales look like they are different thicknesses. Looks like a useful design. :thumbup:
I really like the overall design/pattern of the knife. I'd echo the suggestions made here already. Use it for a few hours and you'll likely find a few hot spots or areas that you may re-profile on the handle.
Other than that, you seem like you're going a very good direction. Keep at it!
what is the last grit you are using for finishing your scales?
