Not sure about the length, I would need to measure the original ones.I am looking at doing the Standoffs too. What are the proper screws want to convert to stainless. Same info is needed for the pocket clip.
Thanks!
Yea I had that same problem so I knocked out the captive nuts and put a short screw in from each side, that way each side could be individually tightened down.
That did two things- I didn't have to drill out the brand new stand off's and it was symmetrical from side to side.
Those are the ringed ones ( no neck) that I was talking about.
I did not think a direct link to knife kits was permitted.
Yes.
The OEM screws thread into the captive nuts in the opposing scale.
So, the standoffs don't really need to be threaded.
But, they are.
The back spacer can be removed without fully disassembling the axis lock.
Take the pivot and blade out of the handle.
Remove the two screws that are going through the back spacer.
Swing the tail end of the back spacer out back of the knife.
The spacer will still be held in place by two platic posts that go into the liners on both sides of the knife.
Now grasp the end of the spacer that is sticking out the back and twist it and gently pull.
Trust me, twist.
The back spacer should pop right out.
If you try this with out removing the blade first, then there won't be enough space between the liners to perform this move.
It's either this way or you need to fully diassemble the axis lock.
Will this trick work with the 707 as well? Mine seems to be hitting the plastic back spacer, want to remove it and sand it down a little. I spoke with Benchmade and they said I could send it in and theyd remove more material off the blade so it didn't hit LOL no thanks.
This trick is not necessary with the 707.
The backspacer is different & comes out very easily once the two screws are completely removed.
Correct me if I'm wrong, But won't Benchmade do this as a free "upgrade"? (outside of shipping of course)
They won't do it just because you ask, they will look at the backspacer to see of the blade's hitting, if not they won't do it.
